주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
Won't turn on - how can I get data?
Hello. Yesterday my surface pro 3 stopped wouldn't turning on. In case it was the battery/power, I tried a couple of different chargers - but both show the pro is charging, and still the screen doesn't turn on. I tried the hard reset by pressing and holding the power button - after about 20 seconds the charger light blinks momentarily before going back to being solid, as if to show the pro is restarting, but still no turning on.
I recently bought a new computer as the pro was getting old, and my concern is not the device, but the data. I last backed up the pro about a month ago. There is data on there I need access to. Is there a way of getting it?
Thank you very much.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @emmie3298
Here's one way which is not that easy but it's doable. Depends how much possible damage to the laptop you're prepared to accept.
Here's the ifixit Microsoft Surface Pro 3 SSD Replacement guide that will help.
Once you have gained access to the SSD (that's the hard part) and removed it, you should be able to then insert it into a PC that has a spare M.2 port so that essentially it becomes a storage drive in that PC and retrieve the data that way from the SSD.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you very much!
댓글 달기
답변을 추가하세요
Emmie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 9
전체 시간: 387
