주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
Dead backlight after replacing key
I replace my wife's C key on her 2017 Macbook Pro, because it was hanging by only one of the retention clips. After replacing all the components of the key, the backlight no longer works. Can this be corrected or has it been permanently damaged?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Ouch! Did you poke to deep and hard? There is a thin sheet which holds the tiny LEDs that light up the keyboard. You either hit the LED near the key or you punctured the foil trace which powers them
Replacing it is a sizable job! Here’s the part A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017 A1708 Keyboard Backlight For Macbook Pro Retina 13" 2016 2017
We don’t have a guide to get you down to it, but give this a view MacBook Pro 13" Function Keys Late 2016 분해도 all you need to do is get the logic board out as well as the fans and the Antenna bar which can be tricky if you don’t use the correct driver
Maybe it’s best to leave things alone ☹️
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alex Brunner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 77
