주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
After audio ic replacement no microphone in phone call but siri works
I recently replaced audio ic in my iphone 7 because the microphone didn't work nor the audio. After checking and continuiti at the pads that every one is jumping there were no bad pads and i didn't rip any of that was used (checked with board viewer and photoshop) should i replace the charging port with the michrophone's or should i try jumping the connections that every one is doing?
The iphone has the freshest ios.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I would of changed the charging port before the audio ic to be honest. That would be your next step.
Update (03/07/2023)
Connections
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
Can the mic prevent the speakers from working? Also it highli depended on the phones temperature weather it had working audio or not. I mean if the phone was cold there was no audio, sir nor could you record or speak and listen in a phone call but if the phone was warm than you could use al these functions mentioned above.
@strongbow
Nigel,
on a side note, i have an iphone 7 that has mic, but not speaker, issue. siri doesn't work, voice recorder doesn't work. taptic has issues but i think that's unrelated. i was thinking Audio IC, but also the charging port flex. i put the motherboard into the back housing of a different iphone 7, but it did not improve things. i would think this confirms audio IC problem.
would you agree? or are there other tests i could/should run?
@mesugemesuge the bottom speaker connection is on the same ribbon as the microphones and charging port.
@beekerc I would fit a new charge port assembly before anything else. Mic, speaker, taptic and charge port all on there.
@strongbow
hi Nigel
i effectively did that. i put the questionable mobo into a different back housing with a charging flex and taptic that work. that's the same as installing a new charging flex. i have another IP7 housing i can try, but i'm not thinking the charging flex is the answer in my case
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Mesuge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 91
