주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
467 질문 전체 보기
How to eject stuck cd?
The cd has a paper sticker on it (is from ADS Tech!!!). I have tried the terminal, Toast, rebooting with left side of trackpad down, the works...
I read that a guy had inserted a flat head screwdriver tip in the cd slot and managed to 'catch' the cd. If I knew the internal 'design' of the cd-rom slot, I might try it.
Any suggestions?
Thank you
PHX
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
To remove he disk without destroying it or the drive, your best bet is to open the machine and open the disk drive. Here's how to get to it: iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement Opening the actual drive usually7 only involves four to six small screws to remove the top and gain access.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Here's a blog post I made answering the very same question on ejecting a "stuck CD" from my iMac. Hope this helps! If you have any questions, let me know! http://bit.ly/GVZg50
Best,
Davey
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
PHX 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 4,994
