주요 콘텐츠로 건너뛰기
The EDV 700 is Rivian's midsize variation of their electric delivery van.
What could cause the 360 camera not displaying?
The 360 camera had been working fine but is now only showing outline of the vehicle and everything else around is so bright and white. What could be causing this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
It sounds like the camera's calibration has become misaligned. I'm having some trouble finding the specific instructions, but their should be instructions for re-calibrating the camera with your van's user manual, and the calibration tool should be in the settings of your vans control panel.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Any one of the 4 cameras could cause this issue or an issue with the display module,to test measure voltage with a multimeter at the center pin of the coaxial connector on the camera, if 12v is found module is good, if not try an info reset using both outer steering wheel buttons, if voltage returns suspect camera, if not use a multimeter to check the cemter pin to the shielding for continuity, if connected suspect wiring, if not suspect module
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lisa Penny 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 284
