주요 콘텐츠로 건너뛰기
2019년 9월 25일에 출시된 7세대 iPad는 32 또는 128GB 모델로 제공됩니다. 모델 번호 A2197.
20 질문 전체 보기
Both cameras stopped working after battery replacement
First of all, I'm new to repairing electronics so bear with me :)
After changing the battery both cameras no longer work. First thought is that I accidentally broke something during the repair, but I'm a little puzzled as to why both cameras are malfunctioning. I'm figuring the problem might lie somewhere else than the actual cameras.
Can anyone help me identify what could cause this issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
So I changed the rear Camera and both cameras worked after that
댓글 달기
답변 1개
가장 유용한 답변
Glad you attempted your own repair! Start by checking the connectors for both cameras. Always make sure to disconnect the battery. Its best to slide the guitar pick next to the battery connector, not directly under it as you can bend or damage the pins. Make sure they're free of debris and foreign objects. Also make sure they're not damaged or missing any pins. Once that is done make sure the connectors have a firm connection. They should snap into place like Legos. After you've confirmed they have a firm connection, you can test the device without fully assembling it. Just make sure you touch the glass and not the actual LCD to interface with the device. The digitizer is in the glass, not the LCD itself.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lars Pugh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 76
