주요 콘텐츠로 건너뛰기
AirPort Time Capsule은 network-attached storage (NAS)/네트워크 -결합 저장 공간 및 가정용 게이트웨이 라우터를 제공하는 무선 네트워크 기기입니다.
Replace airport card/modem in TC gen 4 (802.11N)
Can I replace the Airport Card/Module in the Airport Time Capsule A1409 4th gen (802.11N)?
I fear the answer is Duh, NO!, but the answer is always no if you don't ask.
Thanks, Mark
PS: Is it worth replacing the HD with a SSD?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
While you can’t alter the capsules WiFi interface, you can still connect a WiFI unit externally! As far as swapping out the HDD to a SSD while that can be done, you won’t get the best performance as this units SATA interface is only SATA II not SATA III
So consider your needs, review your cost Vs benefits.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you. Cost is a biggie, but having pieces parts lying around, had to ask those with more experience, skills and knowledge than me.
It works well, as a basic backup, but occasionally I get the Tim "The Toolman" Taylor moments, and want to make it faster, better just because it's (sometimes) possible. ; )
댓글 달기
답변을 추가하세요
mark ray 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 128
