주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Liquid in the digitizer
hey,
so my kids somehow managed to get water inside the digitzer, i tore the device down and its solely the digitizer from the inside, i have let it sit with some silica gel for 10 hours already but there is no sign of the moisture disappearing, i was wondering if i could heat it up with a heat gun/hair dryer so it evaporates faster
thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi
I wouldn’t recommend heating the display as you will most likely burn the glue in between the layers
Unfortunately you may have to buy a new one unless you want to take a gamble
You could also try and disassemble the backlight as that’s where most of the water will gather but please do this at your own risk
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
the thing is, its not the LCD its the digitizer i was wondering if i could heat it up
@hajis
If you use heat below 120deg c you might get away with it
Probably needs replacing though
I would attempt at your own risk:-)
alright thank you ill try my luck
@hajis
Good luck!
Btw I meant 120deg c not 12 XD
댓글 달기
답변을 추가하세요
hajis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 90
