주요 콘텐츠로 건너뛰기
How to fix 512gb SSD instead of default HDD?
I need to upgrade my laptop so I am gonna fix SSD on my laptop for that I need guidance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
@abinesharu93387 do you already have the SSD?
No, I'm going to buy and then fix
@abinesharu93387 Can you confirm your laptop's brand and model?
댓글 달기
답변 1개
So by “fix” I assume you mean you want to replace the old laptop HDD with a new SSD?
If your laptop has a HDD, it most likely has a 2.5” data HDD. You can find 2.5” SSDs pretty much anywhere that sells electronics. Best Buy, Amazon, and I think even walmart sells them. Not to mention the countless online retailers.
Upgrading a laptop to an SSD is typically one of the easier things to do on a laptop but it simply depends.
What is the brand and model of your laptop? This will help up determine what is compatible with your laptop, as well as finding a guide on how to access the HDD and replacing it a new SSD.
If you also want to retain all of your data, consider using a desktop computer to clone your old drive to the new one or use a usb to sata adapter to plug your new drive into your laptop and clone it that way. This adapters are about $10-$15 on Amazon.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abinesh Arumugakumar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 184
