주요 콘텐츠로 건너뛰기
TI-84 Plus calculator support.
Arrow Keys don't scroll through previous calculations
The "normal" behavior of the arrow keys is to scroll up and down through previous questions and answers, but my calculator's ones act like the "home" and "end" keys. I've tried multiple factory/default resets and it still doesn't change.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Press mode and check that you're in Mathprint mode not Classic mode. An OS update to OS 2.55mp might be needed.
You can repeatedly press 2nd then enter to cycle through calculation entries.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Hi
Has the calculator had a battery leak at any point in its life?
If so that may be the cause of the issue
It could also be caused by debris inside the calculator
Here’s a disassembly guide
TI-84 Plus
If you corrosion is found I would recommend cleaning with isopropyl alcohol:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Never had anything related to a battery leak. It just happened today morning, I was doing math work fine yesterday and it scrolled up and down just fine. The up and down arrow keys actually work, but the problem is their intended function (scrolling up and down) have been replaced by the "home" and "end" behavior.
@moony19142
That’s wierd
It might be worth reinstalling the software along side some other things
Here’s a link to doing that
TI-84 Plus CE Recovery Techniques.
댓글 달기
답변을 추가하세요
moony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 37
지난 30일: 104
전체 시간: 2,749
