주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Difference between iPhone 4, GSM and CDMA?
Hi,
So I see some sites are selling parts for the iPhone 4, that are marked as GSM or CDMA. Is there really a difference in the body parts for the two types of iPhones?
I am specifically looking for a 'home' button for a GSM iPhone 4, and seems like the CDMA should work too, is that right?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
This question was migrated from http://meta.ifixit.com/Answers.
can the iPhone 4s CDMA be converted or changed to GSM when someone relocates to a different country or state?
댓글 달기
답변 1개
가장 유용한 답변
Based on our part here, it appears that it is compatible. You are correct in assuming that there are some parts that are the same for both the iPhone 4 (GSM) and iPhone 4 (CDMA). However, not all parts are interchangeable between the 2. The differences between the 2 phones is much greater than that of the iPhone 3GS and iPhone 3G.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Akeel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 5,203
