How to check for continuity in power button?
As title says I want to check for continuity but am not sure how.
좋은 질문 입니까?
좋은 질문 입니까?
The best way to isolate if the button is not working is to use the power pads Using MacBook Pro 2013 2014 2015 power pads if the system responds then the keyboard switch is damaged and you likely need a new keyboard assembly.
Here’s a deep dive into how the button works Macbook Pro Retina bad power button but every other key works!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 43
What are you encountering now? A bit more info would help.
Dan 의
Power button doesn’t work, replaced trackpad fully thinking that was the issue it wasn’t.
asdas sdasdsa 의
