iPhone 7 Apple Logo Loads then Boot Loops.
Hi, I have an iPhone 7 which loads about 5% with an Apple Logo, then seems to crash and reboot all over again. I have tried:
- Rebooting with Front Camera Flex removed
- Rebooting with Screen Assembly completely removed
- iTunes and 3uTools flash
- Both flashes are successful, but after the flash reboot the problem persists
- Reseating the battery
I have heard that other people with the same problem say it can be an Audio IC issue, but the nature of the boot loop suggests it isn't the IC since it does not stay on the Apple Logo, instead it just reboots every 10 seconds.
When flashing using 3uTools, the iPhone actually appears as a device with all the information for about 1 second, before it disconnects and the boot loop cycle begins.
Is there any other suggestions/advice I can try? Thanks.
좋은 질문 입니까?
댓글 2개
Have you tried a replacement battery? This will be your next step in the repair.
Chris Stables 의
@imicrosoldering I haven't. I initially thought it couldn't be the battery since it held charge but it is worth a try. I've just ordered a replacement.
Umar 의
