주요 콘텐츠로 건너뛰기
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
How do I replace the circle pad?
Hello so the rubber cap broke off of my circle pad on 2ds. How do I replace it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
First you'll need to open up the back of the console. Oddly enough, it only has Phillips screws, no tri-wings on this one. There are 2 on the battery cover (they don't come all the way out, but this is normal), 6 under the battery cover, and 4 on the bottom of the unit.
Once you're in there, the white square is the circle pad. It's held in by 2 screws, you need to remove these. Also detach the ribbon cable that's connected to it.
The circle pad should pull right out. You can then install your replacement circle pad by screwing it back up in reverse order.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
tayola 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 430
