주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
Why is my defender not starting
i have a 2001 land rover defender TD5 it has issues starting i have it at my local garage and they dont know what it is they have replaced a load of parts and have got it down to...
you turn the key and it does not turn over the engine and does nothing but when you spray quick start spray into the air intakes and then turn the key it fires straight up.
what is the issues please help!
when you turn the key the car turns over but does not start
they have replaced the pump
it only starts when you spray quick spray in the air intakes
it only turns over if quick start is sprayed
The parts they have check and replaced
test service
 Error-free machine-to-engine diagnostics
 Checking and measuring the electrical wiring with the multimeter / voltmeter, correct
 Rotation sensor replacement (PMS)
 Engine unit (ECU) replacement
 Checking all relays
 Fuel pump and fuel filter replacement
 Replacement of fuel pressure valve with pressure test verified with 4.5 bar pressure gauge
 Replacement of injector seals and washers
 Ignition replacement (by breakdown)
 With this, the engine does not start with a key, only with Start spray
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@archiestorey this " With this, the engine does not start with a key, only with Start spray" sounds like a fuel or timing issue. Does It keep running ones you use starting spray?
댓글 달기
답변 1개
The td5 has a problem were oil seems into the ecu cabling this can cause a lot of issues ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Archie Storey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 52
전체 시간: 615
