Repair and additional information for the Frigidaire FLSC238J*, a side-by-side refrigerator with an in-door ice dispenser, equipped with automatic defrost and an anti-sweat heater switch, introduced in 2008. This page covers information for model numbers matching the pattern FLSC238J*.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
I had a similar issue but with another model of fridge. A lot of the times the issue is part of the lever arm in the tray of the ice maker being jammed up with ice or just frozen. The arm should stick out the back, make sure it is moving freely. There is probably a plunger that the arm sits in at the back near the motor, make sure it can move freely as well.
Not posting this as an answer because I haven't worked with this model of fridge before.
ParmEasyAn 의
