주요 콘텐츠로 건너뛰기
The 2009 Murano made its public debut at the 2007 Los Angeles Auto Show in November and sales began in early January 2008.
8 질문 전체 보기
Why won't my car stay running after replacing my alternator
I replaced my alternator and battery and my car was running fine. This morning it wouldn't start nor my lights worked. I jumped it and got it started then it died again. What could it be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @chrism33416
What is the model year of the vehicle?
Does the battery warning light in the instrument panel glow when the ignition is turned on? If so does it turn off after the car is started (jump started)?
With the vehicle parked and the transmission in Park (AT) or Neutral (MT) and the emergency brake (parking brake) firmly applied, use a DMM (digital multimeter) and check what the voltage is across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC. If not, since you have replaced the alternator, there may be a problem with the voltage regulator in the vehicle, (unless there's a problem with the new alternator or connections to it)
Be safety aware when trying this as the engine is running!
If you don't have a DMM most battery replacement service centres will check it for you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Chris M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 197
