주요 콘텐츠로 건너뛰기
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 질문 전체 보기
PlayStation 3 blank screen, can’t get into reset screen.
Hi, last time I turned on my PS3 it worked fine. Nothing has changed since, using the same TV with the same cables etc.
Now when I turn it on I get a blank screen, have tried different cables, including the component cable that came with the PS3 in different ports.
I have tried the reset by holing down the start button until you get the 2 beeps, with both HMDI & component cable in different ports in the TV, but still just get a blank screen.
Can anyone please suggest anything else I could try??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It sounds like you have already tried some basic troubleshooting steps, such as changing cables and attempting to reset the PS3. Here are some additional suggestions you could try to get your PlayStation 3 working again:
Check the power supply: Make sure the PS3 is properly plugged into a power outlet and that the power cable is in good condition. You could also try plugging the PS3 into a different outlet to see if that makes a difference.
Test with another TV: If possible, try connecting your PS3 to another TV to see if the issue is with your TV rather than the PS3.
Try a different display setting: Sometimes the display setting on your PS3 can get changed accidentally, causing the screen to go blank. Try changing the display setting to a different option, such as 720p or 1080p, and see if that fixes the problem.
Remove any discs or USB devices: If there are any discs or USB devices inserted into the PS3, remove them and try turning on the console again.
Boot into safe mode: Try booting your PS3 into safe mode by holding down the power button until you hear two beeps. From there, you can try restoring the file system or rebuilding the database.
If none of these steps work, it may be time to contact Sony customer support or take your PS3 to a professional repair shop.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi, thank you for the advice. Can you please advise how I change the display settings if I have a blank screen?
댓글 달기
귀하의 답변을 추가하세요
M Draper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 117
