주요 콘텐츠로 건너뛰기
Is it the power supply? Lit LED, 1 none else.
LED stays lit when I plug my iMac G5 in, but when I push the power button, LED 2 flickers on for less than a second and then goes off again. The iMac stays black.
I have tried to reset the SMU by plugging it in while holding the power button, but nothing has changed.
The computer became bricked after a brief power outage (and was the only machine in the house not on a power strip).
mayer wrote responding to "Where is a decoder for diagnostic LED pattern"
LED 1 indicates that trickle voltage from the power supply has been detected. This LED will be ON when the computer is turned off and your power supply is working correctly.
LED 2 indicates that the main logic board has detected proper power
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Replace your power supply.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Thanks. I'll order one and see how it goes!
Well it was the power supply - I'm using the computer to write this follow up. It didn't take hours to fix either - it took half an hour.
I discovered that you may not need to do more than get the front bezel off and lift up the display to swap out the power unit - the hidden connector that otherwise takes hours of disassembly to get at pulls out with a bit of firm-but-gentle sideways wiggling.
My step 18 note "If you are changing the power supply - this is a good point to remove the screws to the old power supply to see if the connectors (both of them) are accessible. If you can gently (but firmly) pull the two-wire connector out from under the chassis, you can install the new unit at this step ...
Live on iMac G5, live on!
Glad I could help you solve your problem ;-)
댓글 달기
I have the same problem only 1 led light up.I have an imac 27 "intel. might be power supply?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
philaro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 801
