주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
129 질문 전체 보기
I have black screen on my iPad but touch works
The touch functionality of the 1st generation 12.9-inch iPad Pro appears to be functioning properly, but there is a lack of illumination on the screen, resulting in a completely dark display. Is there any indication of what the issue might be?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's down to either the LCD or the backlight in this case since everything else appears to be working. Turn out all the lights in the room and hold a flashlight up against the screen and see if you can make out an image.
If so, then the backlight has failed. It could be either a board issue or a display problem; I'm not familiar enough with the iPad to be able to tell you where the backlight driver circuits are and if they're repairable or not, but hopefully some of our experienced Apple technicians will know.
Otherwise if it's the backlight itself or the LCD, either way you'll have to replace the display, which won't be cheap.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
redrott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 37
