주요 콘텐츠로 건너뛰기
1.6, 1.8, 또는 2 GHz G5 프로세서
20 질문 전체 보기
replaced capacitors-no display
I have exactly the same problem after replacing the caps. Did you manage to get this working? I get LED1 and LED2 and even the front light. Going to try adapter for external monitor but have not tried yet. CPU gets hot so it's doing something but the screen is black, no faint image either, and LED 3 does not light up.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Anybody had any luck fixing this yet? I have the same problem...white light..chime...2 flashing LEDs...No display?
댓글 달기
답변 2개
선택된 해법
I was advised that it could be defective RAM or a GPU problem which would need reflowing. I haven't quite got round to either of those solutions but apparently it's quite well known.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
LED 1 indicates that trickle voltage from the power supply has been detected. This LED will be ON when the computer is turned off and your power supply is working correctly.
LED 2 indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 indicates that the computer and the LCD display are communicating. This LED will be ON when the computer is turned on and video signal is being generated.
LED 4 lights only if the computer detects an over-temperature condition. This LED will be OFF when the computer is turned on and running at the correct temperature.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Starscreamer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 534
