Broken ZIF connectors. How do I fix them?
I recently tried taking apart my New 3DS XL only to find out that I'm an absolute idiot. I broke several of the FPC ZIF connectors by lifting them up. My 3DS no longer turns on completely, but instead the power light stays on for maybe three seconds only for it to make an extremely quiet pop and immediately the light turns off. I don't know if the connectors are the reason it no longer turns on correctly, but I would guess so since everything else seemed fine (no obvious torn ribbon cables or partially connected cables).
I would like to know how to repair the connectors. Can I use glue or something to keep the parts I lifted up down? Or should I try my hand at soldering?
좋은 질문 입니까?
댓글 11개
you should add photos, so we can see how bad they are bent, as its hard to tell without any photos 기존 질문에 이미지 추가하기
timtom77 의
@timtomissus I added a few images. They are not ripped off, they just are not snug. I thought that it was strange how they weren't lifting up like the other ones (duh cause they're not supposed to) so I didn't pull up all the way... I lifted e v e r y s i n g l e o n e for a grand total of four.
[deleted] 의
i think the 402C(i think thats the label on it, its kinda fuzzy) connector is chipped, i've used (fingernail) glue on a battery connector on a Nintendo switch joycon before, and it worked, so you could try that, just be careful and don't cover the metal contacts with glue.
timtom77 의
@timtomissus I have no idea how these connectors work, are there diagrams for them? I could try the glue method but I would have no idea what to glue.
[deleted] 의
@m4d83112
https://i.imgur.com/k23RpYs.jpg
this might help
the glue method would work for some time, but might eventually deteriorate/fall off from being dropped, so you might want to soldier them on (or have a shop do it)
also this amazing person might be able to help you even more than i can @flannelist
timtom77 의
댓글 6개 더보기
