주요 콘텐츠로 건너뛰기
2, 2.26, 2.53, 또는 2.66 GHz Core 2 Duo 프로세서
Will the fan of a A1176 fit on a A1283 Model?
Same as above
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Sorry for the delay!
Unfortunately, the fan from the A1176 models has a standard "4-wall" connector, and the fan from the A1283 models has a JST "3-wall" connector. They are not compatible.
Sorry!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
No problem!
It is not urgent, thank you all!
댓글 달기
가장 유용한 답변
Looking at www.mac-pro.com the two fans are enough different to not work properly. The one for the A1176 (1.6 GHz intel Core Duo) has a lower air displacement than the one for A1283 ( 2.0 GHz Intel Core 2 Duo). If you were to put the older one in the newer machine you would most likely run into air flow issues. The physical hight is less on the one for the A1176 so it may fit but not worth the overheating issue.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
+ research
댓글 달기
It would help if you had the part numbers. The expert on parts is Ben Eisenman. He should be to work in about 4 to 5 hours.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
son1c 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,737
