주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
135 질문 전체 보기
My phone is turning off suddenly every 3/4 minutes
I phone 11 pro max problem
My phone is turning off suddenly every 3/4 minutes, then it turns on automatically. Important battery message shows after turning on the mobile. And the mobile is charging at 1%, and no battery health is showing. Again the battery health of the phone is showing for some time, everything looks normal. Then after running the phone again for a while the phone turns off and on again and the Battery important message is showing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
@mehrajsalfi Yeah, here's the key line in your panic log:
Missing sensor(s): TG0B TG0V
According to the kernel panic Wiki:
TG0V and TG0B are a function of the battery.
So yeah, it's time for a new battery, my friend. This guide will show you how to go about replacing it.
iPhone XS 배터리 교체
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yup. This is a dead ringer for a battery problem to me. Right down to the weird battery data.
댓글 달기
@mehrajsalfi, If your phone is rebooting every three minutes then it's almost certainly due to a bad sensor, in this case it's most likely in the battery. Go read the information in @flannelist's excellent Kernel Panic Wiki article and use it to retrieve your panic logs, then come back here and paste the first page or so into an answer so we can confirm the source of your reboots.
iPhone Kernel Panics - iFixit
It sounds like you've got a bad connection going to your battery, as the battery health coming and going is not normal, and you shouldn't be getting the non-genuine battery warning if you still have the original battery or the battery was replaced by Apple, but we can confirm once we see the panic log.
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
i cant paste the panic because it was too long to paste
@mehrajsalfi Just the first part is usually sufficient; just paste whatever will fit into a comment or else you can paste it all into a separate answer.
@dadibrokeit Thanks for your help , sir
2 댓글 더보기
댓글 달기
From my own experience, this is most likely a "Reset Counter" and "Panic Full" error. This is a hardware error that comes from shorted parts on the main iPhone. However, to be able to know exactly, you must have professional knowledge as well as a full range of tools to measure the pulse, otherwise you will need help from technicians.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If the iPhone randomly restarts then this will capture the panic data that you can find as a panic log-on ( Setting/privacy and Security/Analytics &improvement/Analytics data ). This will help to find the faults that I have done by this in my iPhone.Post comment below with log data.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mehraj salfi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 49
30일 전: 191
전체 시간: 667
