주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
79 질문 전체 보기
Cracked MacBook Pro text plate
Hiya!
I've just opened my MacBook for the first time today and the bit that says 'MacBook Pro' has a crack in it. Is this something that can be fixed or is there anything out there like a protector for it so it doesn't get any worse?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This is the chin plate and often breaks when something is wedged between the case and lid.
For now leave the lid up! As you can create a much more expensive repair as the glass shards can cut or damage the displays ribbon cables underneath.
Extreme care is needed carefully removing the plate and replacing it. You may want to visit an Apple Store if you don’t have the skills. The plate can be found here Chin plate bezel
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
It’s not a super difficult repair as far as the logistics, but it requires a lot of patience and “finesse.” There’s a whole minefield of cables under there that could make it much more costly if they are damaged. But it’s definitely less expensive than a whole display assembly. Which is what Apple will do.
@flannelist - I’ve sent a few folks here in Boston to the local Apple Store and they did replace it. There’s where a single crack, not shattered. But different Apple Stores might push the display.
Even still a good independent can do it too.
댓글 달기
귀하의 답변을 추가하세요
Anna Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 42
