주요 콘텐츠로 건너뛰기
2.3L 4cyl or 3.0L V6, 6th Generation
428 질문 전체 보기
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That is voltage to the coil
댓글 달기
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michael Leonard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 218
