I am thinking of upgrading the current Core 2 Duo 3.33GHz to Quadcore
How can i change the iMac processor? and where is the processor located? I am thinking of upgrading the current core2duo 3.33GHz to a Quadcore processor. can that be done?
좋은 질문 입니까?
댓글 6개
which version of iMac 21.5" do you have? (3.06 or 3.33GHz?) Are you looking to upgrade to a faster CPU chip? or do you have a different reason to know?
bac 의
wouldn't a quad already compound the cooling issues in this model of iMac? not issues as in wont work, just as in is really hard on the processor. four cores will run even hotter theoretically.
James Everett 의
any news on this matter??
i have a 27 inch imac ( core 2 duo 3.06) and i would like to know if it possible to install a 9550s
many thanks
Bruno Orfao 의
any success in this matter? i have a 21.5in iMac with the E7600 3.06GHZ processor and i'm thinking of later on upgrading the CPU to match those higher end systems (or upgrade to a 27in then upgrade after that)
Brandon Etheredge 의
Looking to do exactly this upgrade E7600 > Q9550S
Same socket LGA775, same TDP of 65W... Not same FSB... But same as E8600 which was an option at the date of release...
Any one knows, please ?
pfx 의
댓글 1개 더보기
