주요 콘텐츠로 건너뛰기
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 질문 전체 보기
PSU pinout for Apple TV 3rd generation
This is a very specific question, but I hope you can help me out.
I need to figure out what the pinnout of the PSU connector is. The unit itself can be bought, but there are no documents. Also board diagrams are impossible to find.
S/N: ADP-6BF S/ OT9031
https://de.aliexpress.com/item/100500341...
thank you for any help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Have you just probed the board connector to measure things. You basically have two sets of wires for the positive and negative (ground) sides as well as a pair of wires for the power enable.
Using an Ohm meter you should be able to isolate the lines.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Since the ATV doesn't se over 15 W at peak, I'm converting mine to USB C. Thx for the fast reply. I'm mostly interested in the V coming over each wire, so that I design my usb-c power distribution pcb correctly.
댓글 달기
귀하의 답변을 추가하세요
usbc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 13
전체 시간: 77
