주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Why is the home button, sound and computer detect link failed?
the phone was dropped, from the outside the appearance is untarnished but obviously something went wrong inside, it now fails to read when i insert the charger(battery is failing) and the home button wont work either...not only this but sound is failing too...both the earphone dock and the speaker?...would i be better off just buying a new phone or is it fixable??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
it's definitely fixable. You would need to open the phone and check that connector no.4 is on, this controls all of those functions. If you reconnect that and you still have none of the functions then the dock connector will need replacing. I think this is a simple case of a loose connection so you won't need to spend a whole lot of money.This has a handy video to watch that shows you how to open the phone and get to the dock/replace dock. iPhone 3GS Dock Connector
iPhone 3GS Dock Connector 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
thank you kindly..ill check that out and hopefully get fixed up
댓글 달기
귀하의 답변을 추가하세요
rachel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 557
