Rookie help - some fire, melting reattaching trackpad ribbon cable
This MacBook Pro battery replacement is my first computer hardware fix-- as to why I bought a kit and followed a guide.
So... I completed the repair, powered on the computer, and the fans were on full blast, keyboard and trackpad not working. I found another article that explained a loose ribbon or other part may be why. I opened up the case again and checked my work. I saw that I didn't push the trackpad ribbon cable back in its slot on the logic board.
When I tried putting it back, there were sparks, fire, and the pieces partially melted. So I had a frosted mini crisis and realized that I'm in over my head, breaking things. I don't know if this is correct, but I thought maybe I need to disconnect something to reattach the trackpad ribbon cable. I disconnected the battery power connecter from the logic board. This seemed to be the culprit? I was then able to connect the trackpad ribbon cable without fireworks, even though it's somewhat melted, and put everything back together.
Despite my errors and damaging the pieces, my computer works. The battery replacement works. No issues. I'm thankful for whatever luck I have.
My question:
Should I be paranoid that my computer will blow up at some point? The small fire I caused makes me think I'm typing on a ticking time bomb. Is this likely to happen?
Lastly, I think iFixIt should have a warning about troubleshooting your repair. Specifying you have to do things in the instructed order or it could lead to damage. I think its products are intended for rookies like me, and we don't have this basic knowhow.
Thanks!
좋은 질문 입니까?
