주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
317 질문 전체 보기
질문 마감됨
How to startup a clone of my Windows C drive in the Mac.
I have around 250 megs of Windows C drive clone on a 1TB drive in my Mac. I also have VM Fusion, but I have been unable to get the program to work. Is there a way using Fusion to activate the clone C drive?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I think you might have to make an empty virtual machine larger than the size of your clone then do an import.
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
The 1Tb is partitioned such that the remaining 750 gb is empty.
댓글 달기
To run a Windows OS on your Mac, you will need to make a partition separate on to which the Windows OS can be loaded. Next you will need dual booting available e.g. Boot Camp for Mac. then things should load Ok. Make the partition at least 30 to 40 gig's, as Windows uses a lot of disk space to run it, and even more ram to keep it working.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I was thinking of doing that. I was able to find my old Me serial number, so I put in a fresh 500 mb disk and was able to install Windows on it. I will remove one of my Mac internal drives and replace it with the clone of windows to see if that will work. If it does, I will certainly let you know.
댓글 달기
VMware Fusion 3 has a built-in Migration Assistant for Windows:
http://www.vmware.com/products/fusion/mi...
I do not know if this will work with a disk image, but it is worth a try.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I tried VMware Fusion about 6 or 8 times using the migration assistant. I got stuck when I could not enter the PassCode from Windows into the Mac. It also asked for my Administrator name and password from an installation eight years or so ago. I downloaded a Password breaker, but quit from exhaustion. VMware tech service was of no help. They only provide email service, and it came several days after I asked for help.
What OS of win is this?
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 961
