Instead of using the heat mat, can I use a heat gun...
Instead of using the heat mat, can I use a heat gun to take off the screen to get to the battery?
좋은 질문 입니까?
좋은 질문 입니까?
Yes you can. Apply heat around the edges then insert your opening tool freeing a bit of adhesive at a time. Then repeat until the screens off. Using some isopropyl alcohol as well will make the job a lot easier.
해당 답변은 도움이 되었습니까?
Do I need to use plastic picks? or can I use a spudger?
@nytryder26 I’d use a thin opening tool to make an opening then a thin piece of plastic. Plastic picks or a spudger might be too thick cracking the screen.
@strongbow Like this kit? iOpener
@strongbow Ok Ill check it out!
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 70
