주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
Computer turns off when unplugged
So basically I repaired it after it had suffered from light water damage and would not turn on. But after the fix and booting up it shuts off when unplugged and I made sure I got all the corrosion off. The computer says service recommended and I get stats k the batter such as cycles and such but it won’t charge?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Well If the power settings are not normally changed, your laptop may be shutting down after unplugging the power cable. So I will suggest you to check your power setting.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well I’m not sure if it would be that because it’s stuck at 1 percent and doesn’t charge regardless of pram reset and Mac reset
댓글 달기
Sadly, your logic board got wet around the charging logic. This will require either finding someone with the deeper skills to repair your logic board or what Apple would do just replace the logic board! Which is quite expensive.
Where do you live country and nearest major city? Maybe we can aim you to someone that’s close by.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Ya I’ll have to probably bring it in I live in central California
@michaelgar29802 - Are you near SLO? If you are iFixit does have local fix it parties! Give them a call to find out when the next one is.
댓글 달기
답변을 추가하세요
Michael Garza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 122
