주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Lost Nut for Logic Board Screw #13
While swapping out my front display, I lost the nut from the yellow screw in step #13 (iPhone 4 Logic Board Replacement). I was wondering anyone knows of a place to buy this piece? For the time being I just bent the Y bracket down to ground the board, but I would really like to find a replacement. Here is a picture of what it should look like http://i152.photobucket.com/albums/s199/....
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 7개
선택된 답변
This screw and nut are not necessary components. Sure they help hold the shield down. But not necessary for perfect function of the iPhone.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Wrong answer above. The nut serves two purposes: Helps hold the mother board down AND serves as a ground for the wi-fi. This nut is frequently lost when someone replaces the digitizer and they often without it they have poor wi-fi reception (sometimes no wi-fi signal at all).
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
hmm...on the link provided above in the question it isn't the wifi screw (marked green in the picture) that Chris Li is missing, but another screw in the bend of the logic board (marked in yellow) nowhere near wifi antenna ground. Are we all talking about the same screw or is this something you've learned yourself? afaik losing the screw that is marked in green on that photo, renders your wifi unusable...not the yellow.
hmm interesting, thanks for the info. haven't found/replaced the nut on my phone and wifi seems to be working fine, interesting.
댓글 달기
I've been missing that nut since last june and I've had perfect wifi.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same issue I lost the nut on the logic board that the yellow screw goes into (well it broke off) and no wifi I have to put my phone on top of my router to get a signal.
Also the green screw has something to do with reception if you take that out wifi works but very weak.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Snapped off the entire corner that the grounding screw is in because I forgot to remove it. &&&$. In the instructions they should really stress hidden screws. Hopefully if I put it all back together it will still work as everything will still be touching, though it won't be 100%.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I opened 5 iPhone 4 so far and 4 times out of 5 that nut came away, even if I pay attention; that's a very annoying issue.
I think that nut is vital for the gps signal, because after each disassembly the gps wouldn't work. As above-mentioned, I always bend the two branches of the Y upwards and downwards respectively and the gps starts working again.
It could also be a coincidence and the week gps signal could derive from removing the battery and causing a loss of gps data (ephemeris), any ideas?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I've actually lost the nut, which has lead to the microphone not working when making calls!
The only fix I could find was to stick the screw in place with a piece of card, so it still makes contact, and now I can make phone calls again.
Even so, if anyone knows where to get a replacement nut for the screw, that would much appreciated.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,362
