주요 콘텐츠로 건너뛰기
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Display does not show
Display does not show anything
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
hello Shedy willy
If the display of your Infinix Hot 10i is not showing anything, there are a few things you can try:
  1. Check if the phone is turned on: Press and hold the power button for a few seconds to see if the phone turns on. If it does, but the display is still not showing, move on to the next step.
  2. Check if the display is damaged: If your phone has been dropped or has suffered any physical damage, it's possible that the display has been damaged. In this case, you may need to replace the display.
  3. Try a hard reset: Sometimes a hard reset can fix display issues. To do this, press and hold the power button and the volume down button at the same time for a few seconds. Release the buttons when the phone vibrates and then immediately press and hold the volume up button until the Infinix logo appears.
  4. Check the battery: If the battery is low, it's possible that the display won't turn on. Charge the phone for at least 30 minutes and then try turning it on again.
If none of these steps work, you may need to take your phone to a repair shop to have it looked at by a professional.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
not showw a display and sound
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
shedy willy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 765
