The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
좋은 질문입니까?
좋은 질문입니까?
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
이 답변이 도움이 되었나요?
but it can detect my other SSD
지난 24시간: 2
지난 7일: 30
지난 30일: 64
전체 시간: 1,109
댓글 1개
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
Mahedi Hasan Suman 의
