주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sorvall ST 16 Centrifuge - Temperature sensor mechanism?
We have a centrifuge set at room temperature but after a 5 minute spin, samples are cold and frost can be seen within the chamber. Does anyone know how to diagnose and fix this situation?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
This problem was solved by emailing technical support at ThermoFisher. Here was the fix:
"First check that your temperature sensor hasn't fallen in to the motor chamber.  To do this remove you rotor and examine the rubber motor boot.  The sensor should be sticking out of that rubber seal.  If not it has fallen in the motor chamber.  You can remove the rubber motor boot and fish it back up and put it back in the seal."
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your Sorvall ST 16 centrifuge is producing frost despite being set to room temperature, the issue may be related to a faulty temperature sensor, cooling control system, or refrigeration relay. Check the temperature settings and allow the chamber to stabilize before operation. If frosting continues, inspect the sensor and cooling system through the model-specific service procedure. It is advisable to contact a qualified centrifuge technician for sensor testing and calibration before further use.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Small Mechanic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 43
전체 시간: 565
