주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Why is my ping goes very high when playing csgo?
Every time I go on a faceit match my long goes 500-600ms
My ping goes high for 2 or 3 rounds every match
It is very annoying
My average ping on csgo is 60
My average network speed is 100 mb/s but when the ping goes high for ~5 min my network speed is 5 mb/s
I someone tell me how to fix this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
Could be your CPU and/or GPU being outdated or insufficient for running CSGO. Could also be that too much RAM is taken up and you need to clear up some storage.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ping is a network parameter. It measures the time it takes for your ping to go to the target and back. It doesn't have anything to do with your computer. You might want to do a tracert or traceroute to see where in the path the delay is. Ultimately, there is nothing you can do about it.
https://support.n4l.co.nz/s/article/How-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Make sure no other applications or devices are using up your bandwidth. Or, if you’re on WiFi, try switching to a wired connection for a more stable connection.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kozeriukas lt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 246
