주요 콘텐츠로 건너뛰기
The second generation Pathfinder was introduced in late 1995 with more rounded styling. It was completely redesigned from the first generation, switching from body on frame construction to unibody construction.
13 질문 전체 보기
Rear Wiper Arm Wont Park
my 2002 Nissan Pathfinder rear wiper wont park back into its place after running it, and when its turned off, it makes a humming sound every few seconds until i manually go to the back and put it back into its saddle/parked area. how do i fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
https://www.youtube.com/watch?v=C3MXmBwN... seems to be the right youtube with the answer.
Update (07/07/24)
So it turns out all I needed to do was twist the arm a little bit and now it parks just fine.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The motor is most likely burnt out. That'd explain the repeated humming sound. Try replacing it.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
thanks! i will consider trying that, any idea how to replace the motor?
is there a how-to on this?
댓글 달기
답변을 추가하세요
Ezra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 88
