주요 콘텐츠로 건너뛰기
How to fix “Default Boot Device Missing or Boot Failed”?
Power on only comes up with that Setup Notice.
Then Insert Recovery Media and press any key.
Then select Boot Manager to choose a new Boot Device or to boot to Recovery Media. <ESC> gives: “No bootable Device. Please restart system.”
I assume the hard drive is ‘broken’.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
It does use a blade SSD. Go here to find available replacement sticks.
https://www.upgradeable.com.au/collectio...
Meanwhile see if you can boot from an external source if you have it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I usually prefer Samsung or Intel SSDs when this occurs, but the "suicide bit" on the Intel SSD firmware is a deterrent for less savvy uses IMO. 512GB is cheap enough it's worth the extra cost now if you need it.
댓글 달기
I took the pc to our local computer store and I reckon they must have used a recovery boot process to discover the hard disk was OK, but a startup boot file was corrupt.
It's being fixed for $150. Pickup this afternoon. Better than $300 quoted for replacement HDD etc.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Barry Lewis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 605
