36v metabo HPT battery compressor wont start
  • I bought a Metabo HPT air 36v compressor for use with Pnuetmatic tools. I put the filter in, made sure the air tank was empty and made sure the most powerful-fully charged battery was in it. I flipped the switch and nothing happened. I took off and put back on the filter and battery. Still nothing. No help with customer service and to ship it back and get another one always feels like a big deal with items over 200$ of value. Does anyone have any experience or advice?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개:
@bfizzlebilly1 Did you check the voltage of the battery?
Not on that one. I have many more compatible batteries from the same company and none have worked. They have an adapter for a/c conversion. Might have to be my next purchase for Troubleshooting
Does anyone know a way to troubleshoot if my switch is broken?
@bfizzlebilly1 If you can get access to the contacts of the switch, you can use a multimeter in ohms or continuity mode to check for a beep (or low ohms) when the switch is on, and OL, 1, or similar when the switch is off.
It has 1 when the switch is off and it gradually goes to zero when I turn on switch
[image|2970587][image|2970586][image|2970589]
댓글 1개 더보기
댓글 달기
