주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.6 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.2 GHz). 2013년 2월 13일에 출시되었습니다.
Laptop only boots when you do a hard SMC reset
From what the eBay seller of the system tells me:
Laptop only boots when you do this:
  • Unplug power
  • Hold power button down
  • Connect reconnect power
After a few seconds it will chime, then let go of power button
Note it will run with fans at 100% the whole time. Also battery is dead, so if you unplug power, it will shut down. I found this tip on here on iFixIt.
Not sure what is wrong with the laptop, had previously thought it was dead and unable to boot, but it can when you do the above. I have tried SMC and PRAM resets to no avail.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
This sounds like it could just be a dead battery. See what happens if you disconnected the battery and try to power up.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I will let you know when I receive the device I ordered it on Ebay I just posted it so I can get some answers
댓글 달기
답변을 추가하세요
Maimlian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 146
