The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
If the cap gets blown off, there is too much pressure in the crankcase. Blow-by can be caused by piston rings that are worn out. A cylinder with worn out rings will have low compression and will likely cause a misfire. These piston rings need to be replaced.
how many miles are on the truck? What engine do you have?
Jesse Hooton 의
