주요 콘텐츠로 건너뛰기
2019년 9월 25일에 출시된 7세대 iPad는 32 또는 128GB 모델로 제공됩니다. 모델 번호 A2197.
20 질문 전체 보기
ipad 7 no life, charging at 0.08 amps
I bought a broken iPad 7 off the Facebook marketplace. I thought it would be a fun and educational project.
It has shown no signs of life. Replaced the battery, and still has no signs of life. I purchased a USB voltage monitor and tested the charging. It is getting 0.08amp of power draw when plugged into a known good charger. Is this a charging port issue or a possible mainboard issue? or something else?
What are some tests I can perform to diagnose this?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
download a program called 3utool on a pc/laptop, connect the ipad to the computer after installing that check if the ipad is in dfu mode. if it is you can use the program to try exiting dfu but if it goes back to dfu mode or even shows connect to itunes etc it could be a board issue as ipad 7 has a problem with the cpu disconnecting and needs reballed
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Cooper Goswick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 282
