주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Wont turn on at all
Hello i have a 16gb 3gs iphone it worked fine and than i didnt use it for a few months and now when i go to use it it wont cut on or charge or anything no sign of any type of charging when is plugged in either does have the red water dmg sticker but it worked completely fine and have had that for a long time i was wondering what might be the issue or any ideas on fixing this.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
My two guesses are dead battery (possibly finished off by being off for several months) or fried "other component" due to water damage. While the water may not have caused an immediate short, the water may have caused corrosion which built up in the time the phone was inactive. My suggestion would be to open the phone and due a visual inspection to see if anything is noticeably damaged. If all looks ok, try replacing the battery first. Let us know what you find.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
charlie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 823
