Fix the hold close part
Part that holds it close broke
좋은 질문입니까?
I’d first check whether the plastic tab itself broke or if the small spring/hinge piece just came loose.
If the tab is actually broken, the easiest repair is usually replacing the housing/locking mechanism, since gluing a stressed plastic latch often won’t hold for long. As a temporary fix, you could use a small piece of epoxy to rebuild the broken tab, but keep it away from the heated plates and moving hinge.
A photo of the broken area would make it much easier to tell what part is missing and whether it can be repaired.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 9
지난 30일: 20
전체 시간: 249
@amander post some good pictures of what is broken etc. so we can see what you see. Edit your question and use this guide 기존 질문에 이미지 추가하기
oldturkey03 의
Mera Remington stairtinger garm nhi ho raha
Mishal Liaqat Bhatti 의
