이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 4개:
@jordanbillman I know it's a lot of work but we do need to know "check everything I can think of and replaced several sensors and fuzes" what all you have done. Otherwise we all might just be chasing pout tails by suggesting things you already did.
What year is your Dart and what engine /transmission does it have?
A crank but won't start problem narrows this down to one of three possibilities; a fuel issue, a spark issue and/or a crank position sensor/ecm issue. Each issue are relatively easy to diagnose and relies on your diy skills to test and narrow the problem further otherwise a friend familiar with EFI systems or competent repair shop may be necessary to determine where this problem lies.
oldturkey03 의
Probably the starter motor or the battery. I might be wrong, but just in my opinion.
Natan the techman 의
@natanthetechman "my car crank " clear indication that the starter and the battery work.
oldturkey03 의
F Dryer 의
