주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
Memory for Amazon kindle Fire
So i know The kindle fire comes with 8 gig internal for the memory but is there anyway you could take that out and add more? And if so, where could i purchase it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
The memory of the Kindle Fire is in the form of a small IC. You could theoretically purchase a larger chip and install it but these are not plug and play components. You would need a chip with the same pin out/dimensions and the same operating "architecture" as the original. Unless you have extensive knowledge of the inner workings of the current chip and the one you look to purchase as well as special equipment to safely solder these components w/o causing damage.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
+...I would also think that your firmware needs to support the IC as well as the increase in memory...
댓글 달기
답변을 추가하세요
Cody 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 1,319
