주요 콘텐츠로 건너뛰기
Wireless Connecting Device Wi-Fi capable of connecting multiple devices.
[Linksys E5600] Need to set wifi channel manually after restart
My router is E5600, not E1200. After a restart, I need to login to the router page and select and unselect the wifi channel to 'Auto'. Otherwise, it merely shows up on all devices but I can't connect to the wifi from any of the devices. I'm able to access internet via LAN, so that makes it clear the issue is with the Wi-Fi. Can anyone tell me a possible solution to this problem? I can't keep having to login and change the channel manually after a restart
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
I use Linksys Wi-Fi extenders and they were quirky. I have to ask the obvious question - have you updated the firmware? I was ready to junk them at first.
https://www.linksys.com/cn/support-artic...
https://openwrt.org/toh/linksys/e5600
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Normally when I’m having issues with a router the first thing I’ll do is perform a hard reset of the router. This can be accomplished by making sure the router is connect to power and is on then inserting the end of a paper clip into the reset hole and holding the reset button down for 20-30 seconds. Once the router has been reset, you will have to reconfigure it. Make sure that during the reconfiguration process you update it’s firmware to the latest version.
Hope this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tavezzzzo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 245
