주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
What is the high ram acer aspire one zg5 support
what is the high ram acer aspire one zg5 support
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Here is a link to the service manual for your computer. On page 22 it states the maximum ram is 2 GB.
http://tim.id.au/laptops/acer/aspire%20o...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
In practise, ZG5 can only accept 1,5 gigabytes. This is due to following:
  • the chipset limitation is 2 GB
  • there is 512 MB (0,5 GB) RAM soldered onboard
  • there is only one memory slot
So, if you add a memory stick of 256 MB (0,25 GB), 512 MB (0,5GB) or 1 GB you'll be fine as you don't exceed the chipset limitation. 1,5 GB memory sticks don't exist. If you add a stick of 2 GB (or more), you'll exceed the chipset limitation and your ZG5 won't boot.
There are rumors of physically removing the original onboard RAM and then adding a 2 GB stick but I don't personally know anyone having done that. Anyway, I wouldn't recommend it, it would require some skills with soldering iron and such. I also have a vague memory of someone talking about newer ZG5 units having 0 or 1 GB onboard memory, so giving a possibility to reach the 2 GB limit, but I only have met older ZG5's with 512 MB onboard.
이 답변이 도움이 되었나요?
점수 10
댓글 달기
So the solution is to through out the al ready memory and put in thew only slot in new 2gb. Isn it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
LIZ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 17,522
